Results 1 to 10 of 10
  1. I have about 10 hours of pure audio that I would like to break up into tracks. Does anyone know a free program that would take the mp3 and allow me to break it into tracks? I'm looking for something simple.
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    CDEX can probably do it, and is timecode-based.
    If in doubt, Google it.
    Apr 2002
    Oskeeweewee Ontario
    If you've got soundblaster software , then that would be a start...
  4. Member craiggus365's Avatar
    Feb 2003
    too close to Newark, N.J.
    There are many of these called mp3 splitters on any freeware site
    "Quit Playing With The Clock..."
    Rudy - Funhouse pinball game
  5. My favorit is CD Wave.
  6. goldwave has a feature called cue points. check the program out cause it's useful for about 100 other audio editing tasks. i hate getting those one-trick wonders on download.com as they clog your registry after a while
  7. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    I've found an "automatic" mp3 splitter, command line tool (won't clog your registry as it doesn't use it at all!) that can split albums encoded as one MP3 back to tracks.
    Tried it, and without specifying any switches, it split my ELO album perfectly.
    The bad part is, for the life of me, I can't remember the name, nor where I've got it
    /Mats
  8. Banned
    Freedonia
    CD Wave is a really great program and I also use it, but I think it only works on WAV format files. It is really easy to use.
    Nov 2003
    Everywhere I want to be
    Take a look at MP3DirectCut. You can get it from http://www.mpesch3.de
    Wonderful little FREE program that you can set the cut points or have it scan and make a "best guess" for you.
    Nov 2003
    I DON'T KNOW
    You can try ACID XPress. Its a free program base off Acid Pro.
    All you do paint your time line then render your project.
    http://www.sonymediasoftware.com/download/step2.asp?DID=551
