Hi, i want to split my divx film in vdm, but i've a keyframe problem and couldn't cut it from my exact point. Someone said that you can edit the stat file, but i've no stat file (i use dr.divx for dvd2divx). There is no tool to add a keyframe so what do you suggest?
dogano
The only way I know of to mark-in at a non keyframe in VirtualDubMod it get out of Direct Stream Copy mode and reencode. If you have only a few cuts to make you can try the following:
Save from the beginning of the file to 1 in Direct Stream Copy mode as FILE1.AVI.Code:K......1.....K..........K.....2....K...........K K = key frame . = non key frame 1 = mark out point 2 = mark in point ie, you want to remove from 1 to 2
Save from the first K after 2 to the end of the file in Direct Stream Copy mode as FILE3.AVI.
Switch to Fast Recompress mode and save from 2 to K after it with the same codecs and settings as the source file, FILE2.AVI.
Then join the three segments together in VirualDubMod with Direct Stream Copy mode. This way only the one short segment is reencoded.
Video Editing Software: mkv, h264 & DTS Editing?
By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 01:29 -
What is the best editing software for editing head
By sonic12345 in forum EditingReplies: 1Last Post: 4th Jul 2010, 21:05 -
Editing as a career / editing freelance jobs
By ayim in forum Newbie / General discussionsReplies: 8Last Post: 15th May 2010, 21:31 -
Basic editing: which Mac program for my DVD editing situation?
By Nuevonik in forum MacReplies: 4Last Post: 8th Jan 2009, 07:06 -
DV Editing
By m baqar in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 21st Apr 2008, 01:48
