Is there a software converter that will read a DVD with AC3 audio and convert the audio/video on the DVD directly to the Windows Media format?
https://www.videohelp.com/forum/viewtopic.php?t=276275 might assist.
If in doubt, Google it. -
Thanks for the link, but no software listed that will do it in one step. I have found several converter software packages that say DVD to Windows Media, but they don't specify if it will do AC3 audio from the DVD or just mpeg audio.
Here is one software package, http://www.allformp3.com/dvd-to-wmv.html Has anybody used it? -
Good lord! I just followed that link and I see that they're actually recommending programs such as DVDSanta, Xilisoft Video Converter, WinAVI, DVD Cloner, etc etc.
IMHO, most "one-click-wonder" software isn't worth your time and pain. While simplifying the process almost unbelievably so that anyone could do it, you have to lose something, and unfortunately, you lose options, flexibility, and as a result of this, more often than not, quality.
But, if you're happy with what you get out, then good for you
From that link I gave, p_l recommends TMPGEnc Xpress, which allegedly can do it all in one (but I think you'd probably need TMPGEnc's AC3 plugin though).If in doubt, Google it. -
Thanks for pointing out some converters that I thought were mpeg only, like TMPGEnc Xpress. My TMPGEnc Plus copy will not open AC3 audio, it can encode to it with the plug-in, but not open any AC3 audio. Perhaps Xpress can also open AC3 audio?
Can I directly burn a DVD-R from my camcorder?
By debbyandbill in forum Newbie / General discussionsReplies: 3Last Post: 21st Jan 2010, 21:17 -
SubRip can't rip directly from non-encrypted DVD?
By bizzybody in forum SubtitleReplies: 4Last Post: 19th May 2009, 16:37 -
printing directly to cd or dvd
By Ogilvy in forum LinuxReplies: 4Last Post: 5th Mar 2009, 09:57 -
Can FLV's be burned directly to DVD ?
By bvdd in forum Newbie / General discussionsReplies: 1Last Post: 1st Mar 2009, 14:47 -
MKV directly to DVD?
By ezen in forum Newbie / General discussionsReplies: 2Last Post: 11th Dec 2008, 03:47
