Hello everyone, I need some serious help on an issue if thats okay. I recently downloaded DVD Shrink and it encoded some movie files for me which I then thought I could use NERO to burn with but after the movies encoded I got this message and I have no clue what is wrong :( :
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 17/07/2002 9:03:20 AM
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 6:35:34 PM
Nero API version: 6.6.0.16
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Internal Version: 6, 6, 0, 16b
Recorder: <HL-DT-ST DVDRAM GSA-4081B>Version: A100 - HA 1 TA 0 - 6.6.0.16
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD1600JB-00EVA0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST DVDRAM GSA-4081B atapi Port 1 ID 0 DMA: Off
=== CDRom-Device-Map ===
HL-DT-ST DVDRAM GSA-4081B D: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 70254592 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 479MB (490988kB)
Free physical memory: 103MB (106156kB)
Memory in use : 78 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
12.8.2005
NeroAPI
3:33:22 PM #1 Phase 112 File APIProgress.cpp, Line 276
DVD-Video files reallocation started
3:33:22 PM #2 Phase 114 File APIProgress.cpp, Line 276
DVD-Video files reallocation completed (no file modified)
3:33:22 PM #3 Phase 111 File APIProgress.cpp, Line 276
DVD-Video files sorted
3:33:23 PM #4 Text 0 File Reader.cpp, Line 127
Reader running
3:33:23 PM #5 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
3:33:23 PM #6 Text 0 File Writer.cpp, Line 122
Writer HL-DT-ST DVDRAM GSA-4081B running
3:33:23 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3309
First writeable address = 0 (0x00000000)
3:33:23 PM #8 ISO9660GEN -11 File geniso.cpp, Line 3309
3:33:23 PM #9 Text 0 File Burncd.cpp, Line 3233
Turn on Disc-At-Once, using DVD media
3:33:23 PM #10 Text 0 File DlgWaitCD.cpp, Line 270
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 1505503 (334:33.28, 2940MB)
3:33:23 PM #11 Text 0 File DlgWaitCD.cpp, Line 282
Write in overburning mode: NO
3:33:23 PM #12 Text 0 File DlgWaitCD.cpp, Line 2483
Recorder: HL-DT-ST DVDRAM GSA-4081B, Media type: DVD-R
Disc Manufacturer: VDSPMS - AB 01
Disc Application Code: 64, Disc Physical Code: 193
3:33:23 PM #13 Text 0 File DlgWaitCD.cpp, Line 448
>>> Protocol of DlgWaitCD activities: <<<
3:33:23 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 838
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 1505504 (1505504) = #1505504/334:33.29
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1505504 blocks [HL-DT-ST DVDRAM GSA-4081B]
3:33:23 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 1051
Prepare recorder [HL-DT-ST DVDRAM GSA-4081B] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3083272192, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
1505504 | lead-out | 1 | 0x41 | 0x00
3:33:24 PM #16 Phase 24 File APIProgress.cpp, Line 276
Caching of files started
3:33:24 PM #17 Text 0 File Burncd.cpp, Line 4120
Cache writing successful.
3:33:24 PM #18 Phase 25 File APIProgress.cpp, Line 276
Caching of files completed
3:33:24 PM #19 Phase 36 File APIProgress.cpp, Line 276
Burn process started at 2x (2,770 KB/s)
3:33:24 PM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2654
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
3:33:24 PM #21 Text 0 File DVDR.cpp, Line 2379
Recording mode: Sequential Recording Mode
3:33:24 PM #22 Text 0 File Mmc.cpp, Line 21708
Set BUFE: Buffer underrun protection -> ON
3:33:24 PM #23 Text 0 File DVDR.cpp, Line 2534
Start write address at LBA 0
DVD high compatibility mode: Yes
3:33:24 PM #24 Text 0 File Cdrdrv.cpp, Line 8862
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 0.0 (0)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26127F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 2FE10 h
Start sector number of the next Border-In: 2FFA0 h
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................
3:33:43 PM #25 SCSI -1135 File Cdrdrv.cpp, Line 1434
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x061E0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x10
0x32 0x4D 0x03 0x0C 0x0C 0x00
3:33:43 PM #26 CDR -1135 File Writer.cpp, Line 311
Write error
3:33:43 PM #27 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
3:33:43 PM #28 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
3:33:43 PM #29 Text 0 File DVDR.cpp, Line 2774
EndDAO: Last written address was -1
3:33:43 PM #30 CDR -1135 File WriterStatus.cpp, Line 167
Write error
3:33:43 PM #31 TRANSFER -24 File WriterStatus.cpp, Line 167
Could not perform end of Disc-at-once
3:33:43 PM #32 Phase 38 File APIProgress.cpp, Line 276
Burn process failed at 2x (2,770 KB/s)
3:33:43 PM #33 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
3:33:43 PM #34 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\ADPU160M.SYS': Ver=v3.60a (Lab01_N(johnstra).010529-2218), size=101888 bytes, created 17/08/2001 2:07:32 PM
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002) built by: WinDDK, size=16512 bytes, created 17/07/2002 8:05:10 AM
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
You might try DVDDecrypter to burn. If it fails, then either something in the Shink process went wrong or you have a problem with your media.
Ok thanks I will try that....but what do you guys mean by different "media"? .. Im a newbie at computers.
Try a different brand(ie Fuji,Maxell or Verbatim),look for 'Made in Japan'.Originally Posted by drjoy110011
BTW...I get the "Could not perform end of Disc-at-once" error also when burning DVD-Video but not data,I think the problem is with dual-layer burners.Try burning data on a CD or DVD and see if you get the same error. -
Hey everyone!!...from reading the post I wrote in the beginning, can anyone tell me why it didnt burn?
Nero Express stopped working - why?
By TexAsh in forum Newbie / General discussionsReplies: 2Last Post: 9th Dec 2010, 14:28 -
avi to dvd using nero vision 4 not working
By stevencg in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jan 2009, 21:19 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 19:23 -
Magnavox NB500MG9 (walmart) BD player..Nero vision..BD on DVDR working?
By markm75 in forum Authoring (Blu-ray)Replies: 8Last Post: 1st Dec 2008, 02:11 -
AC3 on m4v not working, 48KHz AAC not working, 44.1KHz does?!?!
By dmjerbear in forum AudioReplies: 14Last Post: 11th May 2008, 18:23
