hi there, after browsing through the tool list... i couldnt find any tool that gives you info about the DVD vobs.
I need to know what program was used to create those vobs and the encoder that was used, is there such thing?
Many thanks
+ sorry if its a silly question.
You won't find one as the process of creating the vobs is known as Authoring. vob files are basically mpeg2 files so an mpeg2 encoder needs to be used before you author them which creates the DVD file structure with bup, vob and ifo files.
Some authoring software incorporates an encoder so will accept files in any format, others need them to be mpeg2 already.
See What is DVD at the top left for a fuller description. -
If in doubt, Google it.
If the output is high quality and prfessional in finish, then the techniques and software used should not influence your opinion of their preffessionalism. If they used a freeware encoder would you think less of them even if the results were on par with a $2000 encoder ?
Read my blog here.
Best DVD ripping tool?
By bkkfrank in forum DVD RippingReplies: 4Last Post: 6th Oct 2009, 13:54 -
Which DVD Authoring Tool ?
By Leo48 in forum Authoring (DVD)Replies: 5Last Post: 1st May 2008, 16:37 -
Which DVD Authoring tool to use?
By jodajen2 in forum Authoring (DVD)Replies: 6Last Post: 14th Nov 2007, 10:21 -
Best DV to DVD conversion tool
By whenloverageswild in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 24Last Post: 2nd Nov 2007, 01:50 -
Best tool for DV AVI -> DVD?
By timmus in forum Newbie / General discussionsReplies: 1Last Post: 7th Oct 2007, 12:58
