Im kinda lost here.For whatever reason, the program isnt finding it as if it wasnt installed.Trying to understand what they mean on the site by:
So what did I 'NEED' to download? The one I got seems to be the only one to get!IMPORTANT: This built-in plug-in can only be used with the product containing it.
*You won't be able to use it with another product such as PEGASYS Download products.
It makes possible: Dolby Digital (AC-3) 2ch audio encoding and decoding.
*If the source is Dolby Digital 5.1ch, you will be able to output it even after editing,
however you won't be able to re-encode it.
In my trial version, I see it say:
I see the product has like 3 names and not sure if I got the right one or what.Cannot find the Dolby Digital encoder
Installing the TMPGEnc Sound plug-in AC-3 allows to encode and decode Dolby Digital audio
Can anyone tell me if I need another version or where I should have got the version with the DD encoder.
Can I get this plug-in someplace and install it to the programs folder?
You need the AC3 plugin, and it is not free nor available as a trial.
It does however work with both TMPGenc Express and TMPGenc DVD Author.TANSTAAFL -
It's only a 2-channel plugin AFAIK. If your source is 5.1 it will retain 5.1, but if your source is something else then it will only output 2 ch.Originally Posted by boldego
Something's not right there then .... because ffmpeggui can only out 2 ch AFAIK ...Originally Posted by boldego
... although if you use ProLogic II on your receiver, I believe you can get a "quasi" 5.1 sound out of a 2 ch source.If in doubt, Google it. -
So which TMPGEnc Dvd Author has this plug-in?
What they state is kinda contradicting no?
I only see 1 TMPGEnc Dvd Author to download??
Makes no sense to me or Im not reading it right. -
Yes.Originally Posted by NotSoEasy
By default, TMPGEnc DVD Author does not have the AC3 plugin. It's an optional extra that you must purchase in addition to TMPGEnc DVD Author.
You can purchase both as a bundle here:
http://www.pegasys-inc.com/en/shopping/tda_ac3.htmlIf in doubt, Google it. -
Ahhh, thank you!
I did not see the bundled stuff.
Now time to see if I get busted using the $ CC
Tried the trail on a few things and this was the ease I was looking for in making DVD's !
TMPGenc Xpress 4 and Mpeg Video Wizard DVD VFapi plugin
By stanB in forum Video ConversionReplies: 0Last Post: 28th Jan 2011, 15:46 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
