Hi
When converting a avi file to an mpg-2 for a DVD (in ntsc)
using TMPGEnc, what should i use for the audio:
CBR Linear PCM Audio
CBR MPEG-1 Layer II Audio (MP2)
VBR Linear PCM Audio
VBR MPEG-1 Layer II Audio (MP2)
which one is the standard for a DVD and will be more problem free ..
Thanx
For a NTSC DVD the disk must have either AC3 or LPCM. I don't believe that MPEG-1 Layer II audio is allowed for NTSC. As far as the video the choice between VBR and CBR is based on the total length of your video. Many people will say that if the calculated average bitrate is above a certain amount you might as well use CBR because it is a faster encode. I'm not sure what that bitrate is. I'm sure someone else will let you know.
Tools used: ScenalyzerLive 4.0, Adobe Premiere Pro 2.0, Adobe After Effects 7.0 Professional, Adobe Encore DVD 2.0, IFOedit 0.96, DVD-lab PRO 1.53, Adobe Audition 2.0 -
The software only offer me these 4 choices
so i guest the best should be
CBR Linear PCM Audio ? -
You are telling me that it is smaller for the same quality
so its one more reason for using LPCM -
Originally Posted by bambamRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Convert DVD with choice of audio language and burned-in subtitle language
By theproof in forum DVD RippingReplies: 2Last Post: 24th Jun 2010, 17:34 -
Dvd with choice of audio
By spvideo1 in forum Authoring (DVD)Replies: 14Last Post: 8th Aug 2009, 13:56 -
choice between dvd players ?
By cccf25 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 11th Dec 2008, 14:20 -
Choice of DVD writer
By come_mon in forum DVD & Blu-ray WritersReplies: 3Last Post: 13th Nov 2008, 05:12 -
DVD Decoder Choice
By Parc in forum Software PlayingReplies: 8Last Post: 12th Sep 2008, 02:01
