I'm having trouble with TMPEG, I encoded with it and everything is fine, I want to cut with it I lose audio completely. Anyone out there that can help? Thanks
I had the same problem. This was my work around. I was editing out commercials from my favorite shows so I copied them in sections then encoded them then edited out the portions I didn't want. Then merge them together and encoded again. For some reason TMPEG cause audio to drop out or be out of sync after editing. If anyone else has a suggestion I would like to read it as well.
use a better editor, Vcd cutter is the one I use. A better solution when you can do it is to encode you file in parts using the source limit setting in tmpenc, that way there is no editing and you just encode and burn, you can do them as a batch job and go to bed, it will even shut down your puter when done, then just burn your disks.
Loss of Audio Sync after cutting (Avidemux)
By Maverick-X in forum EditingReplies: 4Last Post: 14th Oct 2011, 15:12 -
TSmuxer Audio Trouble - extremely quiet audio (AC3)
By johnp51 in forum Blu-ray RippingReplies: 7Last Post: 24th Sep 2009, 04:57 -
Cutting 20 ms audio frames
By TrupsT in forum AudioReplies: 1Last Post: 31st Aug 2008, 23:21 -
Mini-DV audio cutting out
By sonicdeth in forum Video ConversionReplies: 2Last Post: 7th May 2008, 18:03 -
Audio cutting question/help
By cowboysroy31 in forum AudioReplies: 0Last Post: 26th Dec 2007, 21:57
