Some help please. I have been ripping with DVDDecrypter + DVDShrink. Now when I go to burn using DVDDecrypter, it keeps burning without stopping. I never had this problem before. Now here is more info. I'm using Prodisc Inkjet printables 8X. Here is info from DVDInfo.
Media Information
Region information N/A not a DVD-VIDEO
Media code/Manufacturer ID ProdiscF01
Format Capacity Blank Disc
Free Blocks 412352512
Free Capacity 4.38GB(4.71GB)
Book Type DVD-R
Media Type DVD-R
Manufacturer Rated Speed Unknown
Available Write Descriptor CLV 12.0x 16620KBps
Available Write Descriptor CLV 8.0x 11080KBps
Available Write Descriptor CLV 4.0x 5540KBps
Available Write Descriptor CLV 2.4x 3324KBps
Write Strategy Speed 4.0x 5540KBps
2x Speed OPC beta 09
2x Speed OPC power 0F
2x Write Strategy field 1 10 88 78 90
2x Write Strategy field 2 29 82 10 21 00 00
4x Speed OPC beta 05
4x Speed OPC power 17
4x Write Strategy field 1 0D 0F 07 07
4x Write Strategy field 2 96 06 0D 0B
4x Write Strategy field 3 80 00 00 00
4x Speed OPC beta multi-pulse 05
4x Speed OPC power multi-pulse 1A
4x Write Strategy field 4 17 96 77 75
4x Write Strategy field 5 7C DF B9 93 11 11
4x Write Strategy field 6 1A AA D0 00 00
Data area starting sector 30000h
Linear Density 0.267um/bit
Track Density 0.74um/track
Number of Layers 1
Complete Media Code
00000000 00 6C 00 00 01 40 C1 FD 9E D8 52 00 02 88 0D 0C .l...@....R.....
00000010 88 88 90 00 03 50 72 6F 64 69 73 00 04 63 46 30 .....Prodis..cF0
00000020 31 00 00 00 05 B8 83 00 30 00 01 00 06 09 0F 10 1.......0.......
I'm down to the last 15 blanks. i'm burning one good or two, and then it keeps burning without stopping and I have to reboot to get DVD out. I'm using Benq1620 pro. I appreciate any help. Thanks to all.
Results 1 to 11 of 11
I would start with trying a different media to rule out the Prodisc blanks. If that still fails, uninstall DVD Decrypter, reboot, reinstall and try again. If that still fails, try burning with another program. Still no luck, think hardware.
Read my blog here.
ok I brought more new blanks. prodisc 8X silver inkjet printables. Never had a problem with them before. Every 4 or five burns, it hangs and I need to reboot since the hitting the eject doesnt help. DVDDecrypter keeps saying, patience I heard you he first time, but it takes too long and then I have to force reboot. Any other suggestions? I now have the Benq DW1640 plus my DW1620 burners. Thanks to all
Have you tried another burn app. such as Nero?
Do the DVD's play ok?
How do you have the drives setup on your PC?
If all writers are having the same problem it's unlikely the problem is firmware,I would:
1.Make sure both drives are set to DMA.
2.Reinstall the IDE drivers(eg Intel,SiS,VIA).
3.If both are on same IDE cable then install a new IDE cable.
4.Set drives jumpers to Master or Slave,don't use CS. -
Have you tried another burn app. such as Nero? Dont like Nero, but I use clonedvd2 and it happens also.
Do the DVD's play ok? yes
How do you have the drives setup on your PC? the Benq DW1640 as master and Benq DW1620 Pro as slave
If all writers are having the same problem it's unlikely the problem is firmware,I would: Yes both drivers having problem.
1.Make sure both drives are set to DMA. Checked an both are.
2.Reinstall the IDE drivers(eg Intel,SiS,VIA). How do I do this???
4.Set drives jumpers to Master or Slave,don't use CS. one is set for master and the other for slave
Thank you for trying to help.. -
Last week I changed the drivers letters from O, P to D & E, to go in alpha order. Could this be causing my problems?
I know this isn't helping you in anyway but DVDDecrypter is an extremely reliable tool and it isnt the program that is causing your problem.(As you already stated,you used CloneDVD)
IMO DVDDecrypter is even more reliable than CloneDVD
Sorry,it is an odd problem you have,wish I could help.~Luke~ -
it really is weird. I just recorded 5 movies no coasters. And I know it's not DVD Decrypter, that software if the KING. I guess I will keep trying to figure out what the hell is happeneing. Thanks
DVDDecrypter not ripping vobs correctly
By vcd4me in forum DVD RippingReplies: 4Last Post: 16th Jan 2012, 17:08 -
Problem: DVDShrink > DVDDecrypter - Layer Break Issue?
By Dave Stewart in forum DVD RippingReplies: 32Last Post: 27th Jun 2010, 21:18 -
DVDDecrypter wants to set Region Code
By src2206 in forum DVD RippingReplies: 6Last Post: 15th Feb 2009, 12:38 -
DVDdecrypter region code not set. Help
By X_Splinter in forum Software PlayingReplies: 2Last Post: 9th Sep 2008, 18:08 -
Imgburn Vs DVdDecrypter
By avextraxjp in forum Newbie / General discussionsReplies: 11Last Post: 9th May 2008, 09:17
