  1. can anyone confirm that dvd2one will not transcode if the original file size is under a DVD5?
    Thanks.
    Zero_Cool
  2. Positive! No compression if original size fits on DVD +/-R.
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    In all honesty, there's probably no need to even use DVD2One if the original file size is under a DVD5. Just rip to HD, and burn, or use DVD Decrypter ISO Read / ISO Write.
    If in doubt, Google it.
  4. Yeah, jimmalenko.
    You might be right. But I'm kind-a-lazy and so I just use DVD2One in conjunction with AnyDVD and CopyToDVD. Almost a one-click-solution. And if the source is DVD-5 or DVD-9 - who cares... I always get the best result with the same method. No need to make it complicated. Set it and forget about it.
    Vid
