  1. Anyone know a program out there that will allow me to dump an entire list of files into it for batch conversion. Programming settings for each individual file is so tedious especially if you have a ton of them.
    Feb 2004
    I am a free man.
    Sorry crystal ball on the blink!!!
    What kind of conversion
  3. avi to mpeg2
  4. Member gobatto's Avatar
    Aug 2005
    Ontario
    By no means am I an expert, but from my limited experience I would use Quenc. You'll need to install Avisynth as well to setup the AVS files. A few calls from the command line to Quenc and you'll have all the switches you want.
    As for the AVS, I use:
    DirectShowSource("filename.avi")
    Converttoyv12()
    Tip: use dir *.avi >> files.txt to create a text list of all the avi files in a path, then open it in Excel (fixed width text) and use basic formulas to create a DOS batch file.
    Hope this helps. Both tools mentioned are available at https://www.videohelp.com/tools/
    Feb 2004
    I am a free man.
    avi to mpeg2
    Try the tools section on the left
    AVI to DVD
    gives you THESE
    Quite a few of these can do batch conversions (tho i dont know this info about all of them)
    I would use TMPGEnc
    If you want to use TMPGEnc see HERE for brief instructions on how to do the batching bit
