Results 1 to 10 of 10
Thread: How can I know if a DVD is pal or NTSC
  1. #1
    Hi
    I would like to know if there is a software that exist that could analyse the content of a DVD VIDEO_TS folder and tell me is the content is a NTSC, PAL or other format.
    Thanx
    Mod Neophyte redwudz's Avatar
    USA
    Posts
    24,327
    If it 25 frames/second, it's PAL. Can't get much easier than that. You should be able to check it with your software DVD player program. The framerate doesn't necessarily decide the format, but 25fps would almost certainly be PAL on a DVD.
    Member thevoelk's Avatar
    Sep 2004
    Forest Hill, MD
    Posts
    405
    You can pull the VTS_01_0.ifo from the disc with a ripper and open it in IFOedit to see what it says.
    Ok thanx
    How can I know the fps with Ulead DVD Player ?
    I did not find anyway to display this information
    Quote Originally Posted by thevoelk
    Ok great its working this way
    thanx a lot
    do you think that any ifo file on the dvd could work with the same trick ?
    Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Posts
    6,727
    You don't even have to rip anything off the disc, you can open it and view it right from the disc with IfoEdit.
    Also you can use a software player or DVD Decrypter or AVIcodec or.........
    to check the resolution and that is usually a good clue also.
    http://www.videohelp.com/dvd#tech
    PAL is usually 720 x 576
    NTSC is usually 720 x 480
    All the specs are in the link i posted.
    I want to check the format of a dvd i don't have
    if I can download only ifo file which are few Kb instead of a complete 4 Gb dvd or a 1Gb vob file
    It would help me a lot
    I just want to know if I can do it with only the VTS_01_0.ifo file of any ifo file can provide me with that information
    thanx
    Member daamon's Avatar
    Melbourne, Oz
    Posts
    4,368
    Quote Originally Posted by bambam
    Try it - for the sake of downloading a few files that are only a few Kb's each, it's not hard...
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
    It seems to work with the downloaded files
    VIDEO_TS.IFO
    VTS_01_0.IFO
    VTS_02_0.IFO
  1. Replies: 33
    Last Post: 28th Nov 2013, 11:33
  2. when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
    By spiritgumm in forum Video Conversion
    Last Post: 13th Oct 2011, 12:57
  3. DVD players that play PAL & NTSC - do you need a PAL television?
    By ibzomie in forum Newbie / General discussions
    Last Post: 12th Dec 2010, 20:53
  4. Replies: 0
    Last Post: 9th Apr 2009, 21:43
  5. PAL VCD -> NTSC Video for NTSC DVD Authoring!!
    By Mickey79 in forum Video Conversion
    Last Post: 12th Aug 2008, 11:30
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
