OK, just so you know I have burnt 1 dvd successfully and now I have a issue with Nero 6.6.0.15.
This is the Exact steps, that I do to burn a dvd..
1.) Select Dvd-Video in the 'New Compilation'.
2.) Click the 'Tab' named 'Label' and give it a name.
3.) Click 'New'
4.) Highlight all the files in my VIDEO_TS folder.
5.) Drag them to the left screen.
When I do the drop and drag I get this error.
How do I fix this?[/quote]The file "VTS_01_1.VOB" is larger than 2 GB and therefore cannot be stored in an ISO file system. Please use the UDF file system to write such large files. This can be done by selecting another compilation type.
Use the UDF/ISO option, check the box that says "Force DVD Compatibilty Mode".
how did you author/make the dvd vob? a vob on a dvd-video can't be bigger than 1gb.
Hi,
Below is a 3 step solution for you and DVD burning in general and it works 100%:
1/ Completely Uninstall/Remove/Delete Nero from your PC!
2/ Completely forget about it!
3/ Get a DVD burning software.
Good luck!
I keep getting write errors in Nero - help :(
By Akhet in forum ComputerReplies: 11Last Post: 30th Oct 2009, 14:51 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 17:02 -
Nero 8 DVD menus simulate fine but transcode errors on final dvd movie
By perfection in forum Authoring (DVD)Replies: 1Last Post: 1st Nov 2008, 04:01 -
burning errors in nero & tmgenc dvd3
By brushuk in forum Authoring (DVD)Replies: 2Last Post: 13th Mar 2008, 12:23 -
DVD Shrink/Nero burn errors
By chibimaru in forum DVD & Blu-ray WritersReplies: 7Last Post: 1st Jun 2007, 04:22
