During record movie (aprox 20 min) then a warning message come up. I tried ignore the message then continue record movie until disk full. When I finalized the disk then it can't finalize and the disk corrupted. I used another new disk then it gives a warning message again during record the movie. I used dvd-r on this camcorder. My question
1. Is there maximum number of frames this camcorder can handle?
2. Does dvd-r disk caused this problem (this DVD is not from Sony)?
3. I copied all single movie frames to my PC before finalize the disk, which software will put these back into 1 disk as play back?
Thanks for your help.
All players/burners are not compatible with ALL media. You could try a different brand media and see if that helps. However, it would be more helpful to know what error message says.
Google is your Friend -
Thanks for replied. I will try another media to see if I have a same problem or not. The warning indicator appear on the screen but I don't know what exactly mean. The trouble shooting section says "Movie recording disabled" or "Disc movie area full, Cannot record movie" or "Scene number full"
To me, it just sounds like you're trying to put too much on one disk. I thnk the warning you are getting is telling you there's no more room on the disk. Try stopping the recording after 15 minutes and finalize, see if that works.
Buy My Books
Finalize DVD-R, is this possible?
By chiyoaiki in forum DVD & Blu-ray RecordersReplies: 35Last Post: 19th Dec 2016, 13:49 -
finalize DVD
By bobaumichedu in forum Newbie / General discussionsReplies: 10Last Post: 14th Sep 2011, 14:59 -
do I HAVE to finalize to rip to HD?
By DirtBikeMike in forum DVD & Blu-ray RecordersReplies: 3Last Post: 26th Jan 2010, 11:22 -
Can't finalize BD-RE?
By DGenerateKane in forum MediaReplies: 0Last Post: 23rd Sep 2009, 19:45 -
finalize Help
By whittyscosie in forum Newbie / General discussionsReplies: 2Last Post: 24th Feb 2008, 14:27
