    Dec 2004
    LOST
    My other PC has intermittent power on problem. If I press the power button("PB"), it will start to run but the moment I release it, it will stop. Sometimes it takes five times or more of pressing the PB before it runs continuously to boot up. Sometimes I have some success if I press and hold it for maybe 5 seconds. Is it the power supply?
    Another info - this is plugged into a surge protector power strip which I turn off when not in use. Usually when I switch it on, the PC start to run and boot up without pressing the PB. It does the same thing to date, problem is the PC stops (after maybe 2 seconds) and I have to press the PB many times. Thanks.
    Gateway P3 600Mhz Win XP 512 MBRAM
  2. Member Xylob the Destroyer's Avatar
    Sep 2004
    Earth, for now
    take your case apart and make sure the switch and button assembly behind the front bezel are properly seated and not broken.
    "To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
    "Megalomaniacal, and harder than the rest!"
    USA
    What Xylob the Destroyer said. Sounds like you have a bad switch. Quick and dirty, you can trade the reset switch terminals for the 'on' switch terminals. They both work the same way.
    Just change the wires connected to the motherboard. If this works OK, then your case 'on' switch is bad. Not so easy to replace, but you might find one that works. If the 'reset' switch works, no big deal. You use the reset instead of the on. Reset is used rarely, and a faulty switch is less important for that use.
    Dec 2004
    LOST
    Thanks, guys. I may have somebody to do this. This is one of the PC components which I have not yet touched.
