  1. How can I get past this. I have used this program befor with no trouble. I had to reformat my hard drive and it hasn't worked since. At first it was telling me, "invalid file or not supported." So I uninstalled it and reinstalled it and now it gives an error code. "Runtime error code R6017 - unexpected multithread lock error" I'm doing everything the same as I used to(Sefy's Guide) and I have the "VFP" file installed in both dvd2avi and tmpge. I'm using version TMPGEnc-2.02.31.119
    Thanks for any help you can supply.
  2. Which OS are you using ?
    Have you tried Deleting the entire TMPGEnc folder, and unzip it back again (first TMPGEnc, then VFP Plugin and then DVD2AVI) in the same folder ?
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
  3. Sefy, thanks for the concern, but nothing is wrong. I'm just a jackass. the DVD2AVI screen was partially off my desktop and I couldn't see the bottom of it. I realized my hard drive was working and it hit me. Let the damn thing finish saving before I try to use it or close dvd2avi. I saw others were having the problem with invalid file and run time error so I'm gonna make a post and hopefully they'll see it. Thanks again man. I'm such a jackass. I've been fighting with this for about a week now. I know PCs pretty well. I should've thought about that
  4. Oh well, in that case, good luck!
    Best Regards,
    Sefy Levy,
