Results 1 to 9 of 9
    North America
    I now know how to:
    * Create an AVS script using Gordian Knot to handle a variety of changes to M2V video.
    * Batch-convert M2V files and AVS scripts of D2V files to AVI files using VirtualDubMod
    * Batch-encode AVI files to M2V files in TMPGEnc
    * Frameserve a single script straight to M2V without re-capturing to AVI.
    Knowing all these steps, I haven't been able to figure out how to frameserve from VirtualDubMod to TMPGEnc in batch. Any ideas?
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Only way I can see, is to run several instances of VirtualDub, start all in frame server mode, setup TMPGEnc jobs for each frameserver and go.
    /Mats
    Dec 2004
    Australia
    Why not just batch convert the avs's?
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    What he said.
    Open the AVS script(s) in TMPGEnc and use it's batch function.
    If in doubt, Google it.
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    /Mats
    Dec 2004
    Australia
    Yeah, but they said that they were opening the avs in VDub and outputting an avi.
    To avoid outputting the avi, they want to frameserve from VDub.
    My suggestion was instead to just work directly with the avs. Same end result. Less hassle.
    Apr 2004
    Miskatonic U
    And probably faster as you are working only with avisynth, and not routing needlessly through virtualdub
    Read my blog here.
  8. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Ah, didn't get it that all these steps where taken in sequence - the way I read it, adigitalman only counted what he knew how to do!
    /Mats
  9. Member Capt.Video's Avatar
    Nov 2005
    I think it was unspoken, but you cant setup VDub to frame serve in batch mode.
    The multiple VDub to frame serve method would work.
    Then using TMPGEnc, open each one and setup *TMPGEnc* to batch encode from the several VDubs you have running.
    Ive never tried it, but I see no reason it wouldnt work!!
    Good luck,
    Andrew
    I have been into computers since 1980. Ive been tinkering with DV in one flavor or another since 1990.
