I got an LG DL writer and made my first backup to test my main DVD player, its a Panasonic DMR E50 Recorder. A good machine, good picture and sound etc but it doesnt like +r disks or RW either. I burned a backup of a disk I own to try if it plays DL disks and it doesnt - dunno if its the dl or +r that it doesnt like tho. Someone said something about book-type and that should play ok - apparently when burning to +r the lg auto sets to book type. The backup disk plays in my Yamada Divx player no problems ( a bit of toast would play on that tho, it plays everything) but the Panasonic says disk error or something, it wont play anyway.
Any suggestions? Am I burning wrong? Im using Traxdata and burning at 2X, using dvddecrypter iso r then w.
Stevie
Glasgow -
Panasonic DVD recorders are not great players. This issue has been addressed at least a dozen times in the past two weeks here. Do a forum search.
Steve,
I too have a fussy settop player that just does not like the +R media. And since DL is +R, I do have a problem. However, I did solve my dilemma by using the burning engine within DVDDecrypter.
Not being at my home computer system, I cannot directly list the menu selections involved but with a bit of searching you can find the menu that lets you change the book type for +R Dl to DVD-ROM. You will need to know your specific burner type in order to complete the change.
Once this has been done, then all you need to do is burn your DVD. Pop it into the player, sit back and watch.
I was very surprised at how simple the process was and more amazingly was that I got the process to work.
Give it a go and see what happens.
Ed
The Complete Guide To Making Blu-Ray Backups (1:1 Backups + BD5 Backups)
By milOtis in forum User guidesReplies: 225Last Post: 21st Jul 2024, 04:35 -
Issue with Panasonic DVD-Recorder DMR-EH55
By chudbeagle69 in forum DVD & Blu-ray RecordersReplies: 28Last Post: 9th Oct 2016, 13:47 -
DVD format issue
By NumbSkUll in forum DVD RippingReplies: 14Last Post: 11th Apr 2010, 19:50 -
Blu Ray Player won't play some DVD backups
By Turpulus in forum Authoring (Blu-ray)Replies: 3Last Post: 14th Apr 2009, 02:00 -
Choosing a DVD player for backups
By akersaz in forum DVD RippingReplies: 8Last Post: 11th Jul 2008, 10:46
