Is there any way to re-author a DVD making no changes (keeping all menus) except for having the sound re-encoded from PCM to AC-3?
(I have made a DVD with maximum video bitrate and 2 PCM audio tracks, and the total bitrate causes problems on some DVD players)
No simple way AFAIK - As you've authored it yourself, it should be a simple matter of encoding the wavs to AC3 (or mp2) and author it again from your source material. Some authoring apps even have the ability to encode wav to AC3 as part of the authoring process, so there might not even be need for manually encoding the wav to AC3 - just check the correct check box!
/Mats -
I found a backup of the project file!
After demultiplexing, AC-3 encoding and re-authoring it works just fine!
iv50 pcm?
By dinofava in forum Video ConversionReplies: 9Last Post: 11th Oct 2009, 10:33 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 04:56 -
DVD Author 2 DTS into PCM 2 problem
By SteamrollerLive in forum Authoring (DVD)Replies: 23Last Post: 23rd Aug 2007, 22:35 -
PCM to Wav
By woodie in forum AudioReplies: 2Last Post: 4th Jun 2007, 11:53
