First my video card went bad, then my dvd burner went bad, then my replacement burner went bad too. then my hard drives(2) started getting currupted data.
So i said to my self how the heck could all these things be dieing? The answer? In my opinion its the HEAT!!! I have a nice computer case its got 1 fan at the top 2 blowing over the hard drives and 2 on the back and one on the front I NEVER thought heat was a problem but i was wrong. i checked the heat in my case and it was hovering around 45c to 50c.
Point being if you want your hardware/computer to last u a long time you need to invest in lots and lots of cooling. My next upgrade is going to be a drive bay fan setup put in the very top of my computer to let all that hot rising air out. With all these heat waves in the summer it has to be causeing people lots of problems and they dont even realize it.
im looking at the posts on this forum and theres like 3 or 4 current topics on harddrives alone going bad!!
Just thought i would share this info/that i had overlooked for quite some time, to help save others many many problems. fans fans fans fans fans
I'm gonna 'customize' and put a 120mm fan in the top of my case, pointing straight up, for exhausting.
"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
yeah thats a good place to put one, i was going to suggest u put 2 fans but then i reread and seen your talkin about big burtha 120mm. which should do you right. the big fans can be noisey so u might need a fan controller to slow it down a bit. but i wouldn't buy that untill u know for sure u need it, execpt they do have probs to take temps for u which could be nice to see before and after installation of your fan.
anyways gl and have fun with the project, check out www.xoxide.com
i think they have some nice bling bling fan grills.
Failing burner?
By Constant Gardener in forum DVD & Blu-ray WritersReplies: 2Last Post: 3rd May 2010, 12:57 -
Sabrent TV-PCIRC TV Tuner Card. heres my problem.
By john518 in forum Capturing and VCRReplies: 0Last Post: 27th Feb 2010, 05:12 -
How to fix choppy / laggy video? (no hardware lag)
By doomed9 in forum RestorationReplies: 6Last Post: 12th Jan 2010, 19:58 -
mkvextract failing
By Paratoxic in forum Video ConversionReplies: 2Last Post: 28th Nov 2009, 17:08 -
wow heres one for you learned people - capture from within
By ancient in forum Capturing and VCRReplies: 4Last Post: 13th Jul 2007, 19:09
