Hi all
when i'm trying to export from Premiere 1.5 with WMV9 the Pan, Zoom out and other movement of stills isnt smooth. if i Export to Mpeg2 its pretty smooth movement, on TV its all cool.
i have both stills and DV footage so i export with lower field.
how to achieve smooth still movement? (in premiere preview window the movement is very smooth after render).
thanx for ur help guys
Hi Ar.Pi,
Welcome to the forums.
The footage you're exporting, with LFF (lower field first) is interlaced. PC monitors show images using what's called "progressive" display.
Viewing interlaced material on a progressive display will result in what you're seeing. This is normal.
As you've seen, displaying interlaced material on an interlace display screen (a TV) is perfectly OK.
So, in short, when viewing interlaced on your monitor ignore the jagged horizontal lines. If you must view interlaced on a PC, use something like WinDVD or PowerDVD - though I don't think they support formats other than MPEG (ans possibly AVI - I don't know).There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
thank u for the quick reply daamon. i've been browsing this forum for few hours b4 posting and i saw many threads with ur reply
ur help is very appreciated
anyway, i just tried to encode (WMV9) with Progressive no interlace and although the stills (Jpeg) r very clear, there isnt a smooth motion on pan and tilt. its as if its missing frames.... :/ (PowerDVD came up with same result) -
No problem. I learnt everything I have from others helping me, so it's only fair to share.
Try exporting the timeline as DV AVI and then use Windows Media Maker to encode to WMV9 (I believe it does it...).There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Movement tracking while decoding
By mrjocke in forum ProgrammingReplies: 4Last Post: 5th Jan 2012, 07:48 -
Movement in my deinterlaced video doesn't look smooth ><
By onlinepen in forum Video ConversionReplies: 2Last Post: 25th Jul 2009, 07:53 -
Application for capturing the screen movement ?
By macmithos in forum MacReplies: 4Last Post: 7th Aug 2008, 15:27 -
Shareware to simulate mouse movement?
By atihelp in forum ComputerReplies: 2Last Post: 24th Jan 2008, 12:20 -
Vegas - Sony Borders Fx, Stills and Pan/Crop
By fredfillis in forum EditingReplies: 3Last Post: 19th Aug 2007, 16:17
