I'm hoping someone can help me out. I've been trying to convert some avi DivX files so that I can burn them onto DVD. The files use the XVID codec and are 624x352. Audio codec is mpga and sampeld at 48kHz. When using ffmpeg, I drop the file in on the summary tab and use the DVD mpeg2enc as the output. I have the audio set to 224 kbits/s and the mp2 format. The first problem I am having is that the video doesn't fill the whole screen when played on the set top DVD. The second problem is that the audio drops out every few seconds.
Some additional info: The avi files play perfectly in VLC and quicktime. I;m using the decode with quicktime option and have disabled the letterbox option. I'm using the default ffmpeg settings otherwise.
I'm using Sizzle 0.1 to create a DVD disc image (video ts) with multiple converted avi's. I haven't had any luck at all with Sizzle 0.5 (which is anothe issue altogether). the resultant image file plays fine on DVD player on my Mac.
Anyone have any suggestions?
Thanks.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
Common DivX DVD Players AVI Playback problems!
By Baldrick in forum Newbie / General discussionsReplies: 8Last Post: 6th Jun 2013, 10:32 -
DVD to AVI (XviD / DivX) using VirtualDubMod Conversion problems.....
By dabas in forum Video ConversionReplies: 1Last Post: 26th Feb 2010, 09:12 -
File conversion problems AVI to Divx
By kaptainm in forum ffmpegX general discussionReplies: 2Last Post: 10th Aug 2008, 20:21 -
Tmpgenc problems with divx avi's, encoder suggestions?
By kitykat_2004 in forum Video ConversionReplies: 1Last Post: 26th May 2008, 02:35
