Hi, i have quite a few TV episodes i was wanting to put onto DVD, and was hoping to put the majority onto a Dual Layer DVD+R.
I have used DVD Lab Pro to author and create the DVD, but for some reason i cant get any programme, Nero 6, DVD Architect 3, DVD Decryptor, PgcEdit to burn the authored DVD Video Files. This is the error messege i get with DVD Decryptor:
"I/O Error !
Device [0:0:0] SONY DVD RW DW-D56 PFS3 (F(ATA)
ScsiStatus:0x02
Interpretation:Check Condition
CDB: BF 00 00 00 00 00 00 20 00 0C 00 00
Interpretation: Send DVD Structure DVD+R DL Boundary Information
Sense Area: 70 00 00 00 .......
Interpretation: Write Protected "
This is the first time i am burning to DL DVD+R, so i would really appreciate any help.
I am running Sony Laptop A417S, 2G pentium M with 1G DDR Ram and a sony Dual Layer DVD writer.
Again, thanks for any help
If you are a registered user of DVDLab Pro, they sell a product called CopytoDVD for $26.00.
This will allow the DVDLab software to burn to a dual layer disk.Whatever doesn't kill me, merely ticks me off. (Never again a Sony consumer.) -
yeah, i tried using that too with no success??
for some reason whatever programme i use to burn, they all come up with errors ???
Thanks for the reply, but can anyone else have any other suggestions as to how i can resolve this issue.
thanks again -
Sounds like it is the media. Your Sony dvd burner probably just doesn't like. It happens. Try a different brand, but to save on costs, buy as few as you can. No sense in wasting money.
Your other option is just to run it through dvd shrink to make it fit on one single layer dvd.TANSTAAFL -
hi, thanks for the reply.
It seems to have done the trick!! I was using Datawrite discs which were not working, and i tried a TDK disc, which worked fine.
thanks for the help
Dual Layer burn issue with TMPGEnc Authoring Works 4
By am_dew in forum Authoring (DVD)Replies: 3Last Post: 7th Feb 2012, 08:36 -
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 03:16 -
dual layer authoring
By miniboss91 in forum Authoring (DVD)Replies: 2Last Post: 20th May 2010, 02:37 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 09:00 -
Dual Layer Burning Help
By MMP in forum Authoring (DVD)Replies: 16Last Post: 4th Aug 2008, 14:34
(ATA)
