Before going the Pioneer warranty route, I thought I'd ask here if these symptoms sound familar.
I'm using a OEM 109 that has been crossflashed to an A09 (Firmnware 1.57). The drive has worked flawlessly since March, but now it can no longer mount a DVD (neither commercial or DVD-R, nor my Tiger Systerm DVD). Audio disks mount and play (via Mac iTunes) and data disks also mount properly. But I cannot write a data disk—Toast reports either hardware errors or media errors. Using the Finder's burner also fails. I haven't tried burning an audio disk, since I assume I won't be able to.
I was very hot here yesterday (close to 99°F), and the drive may have overheated. I burned two data disks successfully before getting errors. I'm not sure if excess hedat could kill the drive, only only the drives DVD capabilities...
Any advice?
Resetting the PRAM didn't help. Since my firt post I tried burning an Audio Cd from iTunes. No go. Same "media" error. Since the drive can't even recognize a DVD, I suspect the media error message is not the real issue.
The DVD laser is probably shot. If the warranty is still good send it back. If not buy a new one, because trying to get it fixed costs more.
NeoDivX 2008 3002.0.1.109
By zebbra in forum Newbie / General discussionsReplies: 5Last Post: 5th Aug 2008, 22:20 -
Region problem with Pioneer
By bltprf in forum DVD & Blu-ray WritersReplies: 10Last Post: 28th Jan 2008, 04:36 -
How do I update the firmware on my Pioneer 109 DVR?
By Boogie7910 in forum DVD & Blu-ray WritersReplies: 2Last Post: 26th Nov 2007, 04:44 -
VideoInspector updated to v1.10.2.109
By Kyle_Katarn in forum Latest Video NewsReplies: 0Last Post: 20th May 2007, 14:03 -
Changing the internal PIONEER DVD-RW DVR-109 Drive's Region Settings
By vidmarc in forum MacReplies: 5Last Post: 4th May 2007, 08:48
