Hi all, first off sorry if this has been asked before, I did a search and did not find anything.
I am converting avi files to dvd format using D.I.K.O. but the audio is is only being converted to analog, is there a way to have the audio be digital so it can play in my dvd player that only has digital audio set up?
Thanks!
NecroscopeV
/bump
If this is not possible or if i am doing somehting obviously wrong could some one let me know so i can quit trying to find a way to do this?
Thanks! -
do you want ac3 dolby digital audio? mpeg audio and pcm audio are digital.
Honestly I will take any audio that would be digital. My source files are mp3 sound. Bascially What i am doing is using D.I.K.O. to convert the avi's and then using DVD-lab pro to build menus. I compile and burn in DVD-Lab and then when i try to play it with digital sound i get nothing. It does work fine on my regular dvd players that are hooked up with just analog. Is there a setting I should be using in D.I.K.O. that will fix this or is the problem in DVD-Lab when it compiles the VOB's?
Thanks for the reply!
Originally Posted by Baldrick -
Sounds kind of like my problem Guns1inger, when i hooked up my dvd player i ONLY hooked up the fiber optic cable for digital sound, i didn't have any other room on my receiver. I have never had a problem with any rented or copied movies, just with the dvd's that i convert and compile myself. Think there is a way on the player itself that i can send analogue sound up the digital cable?
Originally Posted by guns1inger
Converting Analog Tapes (from CCTV) to Digital Format (AVI, MPG...etc)
By leungjing in forum Video ConversionReplies: 2Last Post: 7th Sep 2009, 13:22 -
What to do with large AVI video files taken on my digital camera?
By scormodo in forum Newbie / General discussionsReplies: 9Last Post: 30th Aug 2009, 11:13 -
Converting mp4 files to avi files
By HartsVideo in forum AudioReplies: 1Last Post: 18th Jul 2008, 18:20 -
Converting AVI files to Video_TS files/ffmpegx V0.0.9Y OS is Tiger.
By sadepussycat in forum MacReplies: 10Last Post: 2nd Jun 2008, 15:43 -
Converting digital off air tv streams for Creative Zen (Avi, MWV.....)
By naderro in forum DVB / IPTVReplies: 1Last Post: 17th Dec 2007, 18:27
