    Jan 2003
    I've backup at least 10-15 movies with DVD shrink and I have no problem. I just tried to backup my XXX State of the Union DVD and when it's analysing it I get an error that reads:
    DVD Shrink encountered an error and cannot continue.
    Failed to read file "E:/"
    Data Error (Cyclic redundancy Check).
    What does this mean and can I fix it somehow?
    Thanx,
    Stoked
    Stoked
  2. Member e404pnf's Avatar
    Dec 2004
    Warmington on Sea
    Try a quick SEARCH... of the forum. This is usually a dirty or damaged disk. So try ripping with FabDVD, DDecryptor, IsoBuster or your personal favourite ripping software (with the options set to ignore all errors) after carefully cleaning the disk. Then load this into DVD Shrink.
    - e404pnf
  3. Member GKar's Avatar
    Jul 2003
    In the corner, on a stool
    Try ripping to your hard disk first with DVDFAB Decrypter then use DVDshrink (file mode). DVDShrink is a little outdated for newer titles protections.
  4. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    I had no problems ripping XXX STATE OF THE UNION with the last version of DVD DECRYPTER. Your disc maybe dirty or scratched. Try ripping the disc in another dvdrom or dvd burner or another pc. Rip in FILE MODE with DECRYPTER then use DVD SHRINK.
    Jan 2003
    I used DVDFAB and that worked perfectly.
    Thanx for the help,
    Stoked
    Stoked
