Is it possible to transcode dvdsimple source using several audio codecs simultaniously.
I'd like to convert my DVD's to transport streams with both MP2 audio and AC3 audio tracks.
Is it possible? If yes, then how and if not, then could you suggest any workaround?
TIA.![]()
I Believe Mpeg2Vcr has an option to convert Program Streams to TS files. I can do it with ProjectX, but it seems to require a Demux of the VOB(s), then a Remux into regular MPEG2 files, then back in ProjectX to convert to TS.
Unfortunately, I don't know enough about VLC to help you out in that regard.
VLC: audio OK, PS3: audio out of sync
By brijazz in forum Video ConversionReplies: 6Last Post: 4th Sep 2011, 00:38 -
AVI won't play. VLC say's doesn't support "IV50" Format. All codecs present
By Sikander in forum Software PlayingReplies: 2Last Post: 21st Feb 2010, 07:40 -
Video off in VLC and Audio off in DivX
By indijay in forum Software PlayingReplies: 2Last Post: 28th Dec 2009, 16:05 -
vlc audio problem
By freddeviedo in forum Software PlayingReplies: 2Last Post: 17th Mar 2008, 12:27 -
multichannel audio videoconference with VLC
By grmary in forum Newbie / General discussionsReplies: 2Last Post: 16th Nov 2007, 16:24
