Hi. Being new to this forum the last thing I want to do is get the hair turn up on any ones back, but I have could not help but notice this. Why are people posting templates as a SVCD format when they are -- with all do respect -- closer, or are vcd resolution. I can only make referral to the templates attach to the TMPGEnc SVCD tutorial.
Being new to this editing stuff, maybe I do not see the whole picture :>no pune intended. Could some one explain this to me.
Patrick
im not sure where you are looking... but maybe its got to do with MPEG-2 ...XSVCD?
<font size=-1>[ This Message was edited by: IGuaNAdoN on 2001-12-19 10:49:05 ]</font> -
I went to the tools area and got some of the SxVCD and SeVCD
buy Sefy and also looked at Kobys XVCD.
I just thought they were SVCD templates anything. Am I assuming to much seeing things named similar to SVCD.
Also the SVCD template that comes with TMPGEnc was 480x480 which does not adhere to a proper aspect ratio.
Patrick. -
The SVCD standard calls for 480x480 resolution. If you change this you are making an xSVCD. Sefy's xSVCD template is fairly popular and he calls it SxVCD (he calls his xVCD templaet SeVCD). Also, I think that you are confusing resolution with DAR (display aspect ratio). Take a look at:
http://www.doom9.org/aspectratios.htm
for more info. The popular DAR's are 1:1 for PC, 4:3 for TV: 16:9 for film/movies. You can have these DARs at any resolution (in theory). However, because of the way most TVs are made your resolution has to be divided by 8. Also for NTSC TVs you should stick to ???x240 or ???x480, and ???x288 or ???x576 for PAL.
For NTSC the popular resolutions are 352x240, 352x480 and 480x480 (704x480 for stills, and 720x480 for DVD).
You TV ONLY has a DAR of 4:3. But I can make several different resoltions that have a DAR of 4:3. Does that help?
<font size=-1>[ This Message was edited by: Vejita-sama on 2001-12-20 01:09:01 ]</font> -
Thanks Vejita-sama
I knew it was me! I just needed some one to say it.
Thanks for the pointer I will look at it asap.
Patrick -
I apologise for the confusion with my Templates, first let me say that I never compared my Template or refered it as SVCD, as for the naming goes, the first Template I created was the SxVCD the reason was because it uses MPEG2 VBR so you burn it as Non-Standard SuperVCD.
The Second Template was the SeVCD, which is basicly identical to VCD and is even burned as a Standard VCD, the only diffrence is using VBR, so i figured it's just an enhanced VCD, so there for, eVCD, and not to confuse it with other peoples variations, I give my Templates my name infront, therefor: SxVCD and SeVCD.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
No problem Sefy.
I got allot to learn -- now, if only I can get TMPGEnc to work again. Maybe tomorrow - bed time.
Patrick
DVD Cover Templates !
By MLOR in forum MediaReplies: 8Last Post: 23rd Jun 2010, 05:20 -
Need to convert VCD (352x288) into DVD and crop black bars off
By smashingly in forum MacReplies: 8Last Post: 10th Aug 2008, 06:12 -
512x288 or 352x288 and streched player to simulate 16:9
By Fking in forum Newbie / General discussionsReplies: 4Last Post: 7th Jun 2008, 09:30 -
DVD templates
By anfield7 in forum Newbie / General discussionsReplies: 2Last Post: 3rd Dec 2007, 02:16 -
I enter 352x288, but it always produces 320x240
By markwm in forum ffmpegX general discussionReplies: 2Last Post: 9th Jul 2007, 21:23
