  1. I have been using Svcd2Dvd since feb 2005 and have never had a single problem. But today While I was using the program this error keeps coming up when the menu is 57.1% encoded.
    Version: SVCD2DVD 2.0
    Build: 2.0.2034.36335
    Type: System.InvalidOperationException
    Source: System
    Message: Cannot process request because the process (2620) has exited.
    InnerException:
    StackTrace: at System.Diagnostics.Process.GetProcessHandle(Int32 access, Boolean throwIfExited)
    at System.Diagnostics.Process.GetProcessHandle(Int32 access)
    at System.Diagnostics.Process.set_PriorityClass(Proce ssPriorityClass value)
    at x3284ccece41ee22b.xc5b4b7804027a156.x160a0bf4de8f6 bd0(String xd168ac2ed64c4662, String xa6a477a49a1a2599, String x450f47a9028f884b, xa0efedb9fec1e88f x8b49c96cd0348808, Boolean x74effd3a0f44569e)
    at x3284ccece41ee22b.xddb8d1ea6c9958c7.x8291881ef07bb 5c7(Boolean x7ce1fdb24a74c398)
    at x3284ccece41ee22b.xd3764d4f1e921081.x4f3432523597d cf6(Boolean x7ce1fdb24a74c398)
    at x3284ccece41ee22b.xd3764d4f1e921081.x2e6504f39decc 498()
    at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Can you post or email me your log file for this run please?
  3. here is the log file from when I last tried
    =================== AV Details ===================
    file=F:\downloads\Bad News Bears (2005) (2 CD)\hy.bnb.cd1.part01\hy.bnb.cd1_S2D.mpg
    Num_Frames=108265
    DurationInSecs=3612
    Duration=01:00:12.4
    VideoCodec=mpeg1video
    Width=352
    Height=240
    Standard=NTSC
    BitRate=1434
    AudioStreamCount=1
    Audio1SampleRate=48000
    Audio1Codec=mp2
    Audio1BitRate=224
    Audio2SampleRate=-1
    Audio2Codec=NULL
    Audio2BitRate=-1
    05:08:01: Leaving hy.bnb.cd1_S2D.mpg alone. File has Nav Packs
    05:08:01: Done: Processing assets for DVD creation
    Authoring DVD Folders
    05:08:01: Creating TitleSet # 1
    05:08:02: SVCD2DVD: DVDfolders
    Generating DVD folders please wait....
    05:08:02: -->: DVDFolders creating VTS
    05:08:02: -->: VTS 01
    05:08:02:
    DVD Folders: Processing C:\Program Files\BadgerIT\SVCD2DVD v2\dummymenuNTSC.mpg...
    05:08:02:
    DVD Folders: Processing F:\downloads\Bad News Bears (2005) (2 CD)\hy.bnb.cd1.part01\hy.bnb.cd1_S2D.mpg...
    05:09:04:
    05:09:04:
    05:10:24:
    05:10:24: Finalising DVD...
    05:10:24: Encoding menu...
    05:10:29: ffmpeg version 0.4.9-pre1, build 4757, Copyright (c) 2000-2004 Fabrice Bellard
    05:10:29: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --enable-vhook --disable-debug
    05:10:29: built on Jul 27 2005 15:48:58, gcc: 3.2.3 (mingw special 20030504-1)
    05:10:29: Input #0, image2, from 'C:\Program Files\BadgerIT\SVCD2DVD v2\menu\background%d.jpg':
    05:10:29: Duration: 00:00:00.0, start: 0.000000, bitrate: N/A
    05:10:29: Stream #0.0: Video: mjpeg, yuvj420p, 720x480, 25.00 fps
    05:10:29: Output #0, rawvideo, to 'C:\Program Files\BadgerIT\SVCD2DVD v2\menu\backgroundES.mpv':
    05:10:29: Stream #0.0: Video: mpeg2video (hq), yuv420p, 720x480, 29.97 fps, q=2-31, 1000 kb/s
    05:10:29: Stream mapping:
    05:10:29: Stream #0.0 -> #0.0
    05:10:31: video:332kB audio:0kB global headers:0kB muxing overhead 3.879540%
    Nov 2005
    I got a similar error today at 0.0%
    Any ideas?
    Build: 2.0.2146.38069
    Source: System
    Message: Cannot process request because the process (3748) has exited.
    InnerException:
  5. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Can i see the log file please?
