1st off I can play the whole dvd, for this example but not only this instance, I loaded 8 cam recorded video clips . Hit play and at the end of the clip/chapter the dvd stops, like the dvd is finished. If you start the dvd and jump to the next clip you can view them all. This happens wether I use 2 clips or 10, at the end of each one it stops and you have to start the dvd over, to get past the first chapter you have to skip to the next chapter.
Click on the connection option under your project and in the panel that opens, just right click on draw connections and then manually draw the links from clip1 to clip2 then clip2 to clip3 and so on. For the last one return it to your main menu.
You can also redraw your first play and title options to point to your first menu if you don't want the movie to start right away. -
Your problem is that you have 8 titles, not 8 chapters. If you want to have them act like chapters, do as the previous poster suggested, but also put a chapter stop as close to the last frame as possible for the first seven clips. This will give you somewhere to 'Next' to.
Read my blog here.
Slight Pause at the End of Each Clip (MTS files)
By Obtong in forum EditingReplies: 4Last Post: 10th Aug 2011, 00:53 -
Playback with MPCHC while still capturing stops at old end of file
By suppa in forum Capturing and VCRReplies: 0Last Post: 30th Dec 2009, 15:11 -
How do I remove chapter stops?
By Ronny G in forum Authoring (DVD)Replies: 5Last Post: 9th Apr 2009, 08:42 -
audio stops way before end of converted movie and is out of sync
By jboyd in forum ffmpegX general discussionReplies: 11Last Post: 17th Dec 2007, 06:12 -
Video stops after intro - is it a chapter-problem or just corrupted?
By offtherecord in forum Software PlayingReplies: 2Last Post: 21st Nov 2007, 10:38
