hello need help , i was wondering if it is possible to put 5 or more dvd writer in one pc? i was thinking of using the ide to usb adaptor that has its own power supply, and connecting it to the pc, is this posible? experts me need help regarding this and what software to use for burning
and second i was wondering it its posible to do this, lets say i what to burn all my file to the dvd as back up and have 20gig and i has 5 dvd burners, is it posible that it would automatically copy the file and seperate it to the 5 dvd media? just wondering if this is possible
cause i burn a lot of dvd lately and was wondering if this are possible, this will surely help me a lot thanks you in advance
Results 1 to 9 of 9
what are my alternatives to setup a multiple dvd writer , any links where i can learn? thanks
Buy one ready built, do a Google Search for different companies that build them. Or click on one of the ads at the top of this web site? Simple?
I would second what jdizzy40 said. If you want to burn that many copies at once, an external box with SCSI or possibly Firewire may work.
USB, No way with that many writers. The bandwidth is too much.
If you had a tower computer case and 3 or 4 DVD burners you could do it fairly easily. You will probably need a PCI IDE controller for the extra drives. Nero can do multiple copies, really not that hard. Stuffing 5 DVD burners into a tower case, not likely.
I would go external for that level and it's a lot easier to buy a box set up for that purpose. Look around on the net for DVD duplicators. -
thanks
i think im going with the dvd duplicator, any recomadation on what type or brand to buy? or can we setup it up parts by parts? or go pre made? -
There are a lot of them out there, all levels and prices.
Do a 'Google' search for 'DVD Duplicator' for starts.
You should be able to find several boxes that are 'bare bones' where you add the DVD drives. For that many copies, you would probably need software better than Nero for multiple copies. That should be available on the same type of websites. The boxes may need a SCSI or other type of high speed interface. That would require some type of PCI card installed.
It's not that complicated. You just need to create a master copy and duplicate it. Be aware that these will be burned DVDs and not necessarily compatible with all DVD players. -
I will burn two movies at the same time: Two DL burners (Nec internal and SOny exteranl (firewire) and after a batch job with Rebuilder Pro I'll burn one ISO image with Nero and another with Copy to Dvd both at the same time...perfect (yes, I watched both and they both were perfect) use TY's 01 or 02. My processor is AMD 64 3200.
Setup default dvd player
By bambam in forum Software PlayingReplies: 15Last Post: 26th Jul 2014, 21:07 -
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 09:27 -
Invalid DVD / Multiple errors with multiple programs...
By multiplex in forum Newbie / General discussionsReplies: 10Last Post: 6th Oct 2009, 16:50 -
Authoring Multiple Language DVD with multiple language menu options
By kemimich in forum Authoring (DVD)Replies: 7Last Post: 8th Sep 2008, 17:29 -
DVD / TV / MKV setup!
By danielbanks in forum DVD RippingReplies: 4Last Post: 10th Aug 2007, 04:35
