I received some boxing matches on dvd-r, the volume is very low.
How can I increase the volume ?
You have to rip the VOB files to your hard drive, demux the audio from the video, load the audio into an editing program and increase the volume, then remux the audio and video streams, then re-author the DVD.
Goldwave or Audacity are good freeware audio editors you can try.
Might be lots easier to just turn up the volume on the TV or receiver. -
What free programs can you use to demux video from the audio and then remux the streams?
copy You Tube to DVD,sound leave problems..
By gary153 in forum Newbie / General discussionsReplies: 1Last Post: 16th Oct 2010, 08:33 -
Low Sound Output After Adding .ssa to .avi
By edlimym in forum SubtitleReplies: 4Last Post: 12th May 2010, 08:02 -
Low sound in rear speakers.
By madman1987 in forum AudioReplies: 5Last Post: 24th Nov 2008, 13:44 -
low sound after burning to dvd
By ymurf in forum Newbie / General discussionsReplies: 3Last Post: 3rd Feb 2008, 15:59 -
LOAD CLICK AND LOW SOUND at join of 2 avi xvid ac3 using vitualdub
By hawklight in forum EditingReplies: 0Last Post: 15th Jul 2007, 09:44
