Hi,
I'm using nero v6, my temps folder was on a different HD, this HD is dead.
I'm using easyrecovery to recover everything.
Now I want to burn the recovery data but Nero doesn't respond, cause it's not finding the temps files wich is not availaible anymore.
So is there a way to change the temps files directly into a file into the programmfile?
Cause I can't change it into Nero setting, nero does not open at all.
Thanks for your help!
If memory serves me.. its been a long time since I even attempted
such nonsense, because I just let the desaster go, and move on.
Anyways..
When you recover a given file, it's first letter/char is removed
and turned into a "?" char.
Assuming these file are now restored, and as long as you:
* remember the folder name (and location) where there were before,
* and the first char of the filename..
(You have to rename the file(s) to original name, because Nero
will have probably stored the name(s) somewhere's. Then, you have
to create new folders, remembering what the last folders were
during the Nero process, and name them as such. Then, you have to
copy (or move) the file(s) back into these folders. Then, go into
Nero and see if it will take. If it doesn't, you might try hitting
the BACK or PREVIOUS button, and then try again.
Sometimes, that works. But, sometimes not.
Then..
You (Nero) should be able to continue with the process.
I think. Only theory here
Good luck,
-vhelp 3498 -
Hi,
Thanks for the solution.
I don't think it will work but I will give a try and let you know.
maybe the easiest way is to desinstall and reinstall Nero so it will probably use the by default setting.
thanks -
Open Regedit,
then go the HKCU\Ahead\Nero - Burning Rom.
Browse all the keys and change the temp path in all needed keys.
Then try restarting nero -
I find it hard to believe Nero won't open at all. I would expect Nero to open but give you some sort of error because it cant access its temp folder. Are you sure Nero wasn't installed on the bad drive?
Google is your Friend
RipBot264 Temp Folder
By jotpilot in forum Blu-ray RippingReplies: 12Last Post: 11th Jan 2012, 17:45 -
WPDNSE folder inside your system Temp folder????
By MozartMan in forum ComputerReplies: 25Last Post: 27th Mar 2011, 09:35 -
DIKO 2.47 Temp folder problems
By chirayuw in forum Authoring (DVD)Replies: 1Last Post: 6th Jul 2009, 06:26 -
how to delete the TEMP folder contents in windows?
By sumeshkri in forum ComputerReplies: 4Last Post: 3rd Sep 2008, 14:27 -
why canīt find FLVs downloaded by means YOUTUBE on IE7 temp files folder ?
By RonWolpa in forum Newbie / General discussionsReplies: 8Last Post: 8th Jun 2007, 08:16
