Hello i have a dvd that i copied.
It worked fine when i copied it but now when i go to clone it i get errors.
Is there a program out there that will ignore the error or possibly fix it?This one disc is VERY important to me.
It is an interactive type dvd with many menus to choose from.
Any help would be "GREATLY" APPRECIATED!!!!!
aT 23% DVD Shrink "Data Error (cyclic redundancy check)
Results 1 to 9 of 9
Use DVDFab Decrypter or change setings in DVDDecrypter to ignore read errors.
~Luke~ -
The error your getting is a bad Dvd disk or a possible Hard drive error. If its your hd it means its breaking down time for a new drive.
If its your Hard Drive,sorry but things will probably only get worse.I've had this problem in the past and more and more of the hard drive deteriorates over time.
~Luke~ -
Its not your Hard Drive then.
Try doing what I said in my previous reply.~Luke~ -
DVDFab Decrypter seemed to read it fine.
Now how do i burn that?
DVD clone didnt seem to wont to accept it to burn?
It saved it in afile called dvd,i selected the dvd file in clone dvd then it gave me an error? -
Burn with DVD Shrink-it'll use Nero or DVD Decrypter.
I believe its not your HD but one of: bad media; dirty media on underside of disc or possibly DVD drive itself. I had exact same errors on mine and it turned out to be the drive. Some members may differ from that but give it a try on a RW disc-nothing but a few minutes of time to lose. -
Originally Posted by allsmiles42240
/Mats
Copying DVD's with Shrink and decryptor
By LeeRobertE in forum DVD RippingReplies: 6Last Post: 26th Feb 2011, 14:46 -
Errors on Shrink ripping latest hit dvd's
By bluzjamer in forum Authoring (DVD)Replies: 9Last Post: 6th Dec 2010, 00:13 -
ImageSource giving errors when reading Photoshop .bmp files
By DVD_JS in forum EditingReplies: 0Last Post: 20th May 2008, 18:21 -
DVD Player is giving me trouble wth DVD-Rs
By Veepa in forum DVD & Blu-ray PlayersReplies: 4Last Post: 27th Nov 2007, 10:31 -
DVD Shrink/Nero burn errors
By chibimaru in forum DVD & Blu-ray WritersReplies: 7Last Post: 1st Jun 2007, 03:22
