Adobe Premiere Pro
I open a project and it quickly exists to the desktop and when I enter again, it won't even load up at all. Double click and nothing happens.
Has this happened to you guys before? It was working fine a week ago and it suddenly just refuses to open up.
I fixed it..
I think I improperly saved the project, so if your project crashes on you and you quickly are back to your desktop, then you know its cause you messed up the saved file, but simply just go to your auto-save folder where your copies are.
Very helpful info for those in the same situation which happened to my friend as well, so I assume this is NOT uncommon. -
So did you simply doubleclick your last good auto save file??
Adobe premiere cs5 crashes on start-up
By sonic12345 in forum EditingReplies: 14Last Post: 13th Nov 2010, 18:16 -
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 04:22 -
crashes
By idolgolf in forum Newbie / General discussionsReplies: 3Last Post: 10th Mar 2010, 05:43 -
Premiere Crashes on 720 P 25 capture
By Dejablues in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 25th Oct 2007, 10:14 -
Adobe Premiere project using AVISynth AVS scripts crashes when rendering!
By Mark001 in forum EditingReplies: 2Last Post: 10th Jun 2007, 23:25
