I have been beating my head against the wall for 2 weeks now. I take my DiVX AVIs and convert them to the DVD ffmpegx option without creating the VIDEO_TS folder structure as I want to pull them in Toast so I can at least get some chapters in them.
I convert just fine in ffmpegx. It creates the .mpg, .mpv, and .ac3 files just fine. They import into Toast 6.1.1 just fine. It finds the .ac3 surround sound file just fine ( I have Toast with Jam).
When I go to create the disc, Toast RE-ENCODES the entire video files and then burns the disc. The resulting image is TERRIBLE.
I know I read in the ffmpegx docs that when it creates the mpg2 it should work just fine in Toast and Toast should not re-encode the files. Why is this happening and is there a fix for it? I have the latest updates for both Toast and Jam and am using the 0.0.9s version of ffmpegx.
Thanks!
This is just a shot in the dark, but Toast only supports framerates of NTSC (29.97) and Pal (25). If you are encoding to NTSC film (23.97) then you need to add 3:2 pulldown for Toast to accept them. If this is the case, change your .mpv extension to .m2v and use the pulldown button in the tools tab of FFMPEGX.
Cheers,
Alph
ffmpegX and/or Toast 8 - Loss of video quality in converting to DVD
By bonespur in forum MacReplies: 2Last Post: 9th Mar 2011, 01:52 -
Newbie Question about Avi's, ffmpegx and Toast
By pmmassacre in forum ffmpegX general discussionReplies: 12Last Post: 25th Apr 2009, 23:38 -
Weird Toast and .ac3 5.1 problem
By Direwolf in forum MacReplies: 2Last Post: 25th Nov 2008, 19:29 -
ffmpegX and Popcorn 2/Toast 6 (Light)
By charliel52 in forum ffmpegX general discussionReplies: 1Last Post: 30th Aug 2008, 14:10 -
toast not accepting some movies converted to pal as is
By jboyd in forum ffmpegX general discussionReplies: 4Last Post: 24th Jan 2008, 19:10
