I have done a cursory search of the forum and not found any info. I can burn DVD+R discs and play them on my Mac. I have a player hooked to the TV. It is supposed to play all the various media. But it won't play the +R disks that work fine in the computer. Now this isn't a problem since I can just use -R discs. But I'm considering getting a new dual layer Lacie burner. But the dual layer format is +R. Do any of you have ideas as to why the +R discs won't play on my player? I guess that would be a problem for the dual layer +Rs as well?
thanks
Mike
There is a 4 bit field (book type)at the beginning of every DVD that defines how a player should process the disk. Set top players made before mid 2004 don't process the +R. There are alternatives.
1. Use -R DVD's.
2. Use +R DVD's in a burner that allows bitsetting. A +R DVD written with a DVD-ROM bit code will fool an older player into playing the disk.
3. Buy a newer set top DVD player that processes +R DVD's.
There is a wealth of information available at:
http://club.cdfreaks.com/
My other computer runs o.k. after my browsers finally load...
By tcory in forum ComputerReplies: 3Last Post: 2nd Jan 2011, 21:28 -
Winavi Runs Slow On Old Computer Any Way To Speed It Up
By DJboutit in forum Video ConversionReplies: 6Last Post: 3rd Jan 2010, 17:36 -
Authored DVD runs on player but appears blank on Windows
By bluheat in forum Newbie / General discussionsReplies: 3Last Post: 20th Aug 2008, 12:03 -
dvd plays on stand-aone player & TV, but not on computer
By ibzomie in forum Newbie / General discussionsReplies: 1Last Post: 19th Jan 2008, 15:18 -
SONY Burnt DVD+R's Work Fine in Stand-Alone, But Won't Playback in Computer
By MYSTiCKWARLOCK in forum MediaReplies: 3Last Post: 13th Nov 2007, 02:27
