Hi i was a registered user of this prog a few years ago and have just donated and got access once again I notice alot of changes
Anyway I have some questions.
If i have two or three BIN/CUE files that I want converted to dvd.
How long would the process take from adding them as assets and selecting Quick DVD??
MY PC has 512 memory and 1.8ghz speed
This prog has been reliable 2me in the past, and it is alot easier than tmpeg+dvd author as it can just be set away and left.
Is there anywhere that has conversion rate. e.g the total size inputting= x amount of hours
You'd need to provide more info before you can get an estimate.
Are your files svcds? avis? NTSC? PAL? Which TV format do you want the results to be?
If you have for example 3 NTSC svcd files you wish to leave in that format, & combine as one finished DVD, I'd guess the time would be under an hour or so, including converting bin->mpeg. If they are avis, it will also need re-encode time, as would format conversion PAL->NTSC
Quick Question
By TagFan in forum DVB / IPTVReplies: 3Last Post: 26th Sep 2011, 10:45 -
New here - Quick questions
By ImportGuyR34 in forum Authoring (DVD)Replies: 6Last Post: 10th Mar 2011, 08:11 -
Quick Hello :)
By Paul Iddon in forum Newbie / General discussionsReplies: 1Last Post: 17th Feb 2010, 18:14 -
Maybe some quick advice
By jfharper in forum ProgrammingReplies: 0Last Post: 9th Nov 2007, 23:49 -
Quick Help On Audio
By dbanga in forum AudioReplies: 2Last Post: 17th Jun 2007, 16:35
