I am running XP and cant capture in higher resolution than x288. When I had Windows ME it worked fine and I could capture in full resolution. I have tried with different capture software but them all syas the same: "Unsupported Video Format". I think it is strange because the card worked fine in Windows ME. I have download the latest drivers but I still can't capture above x288. I think it has somethin to do with the WDM driver that XP uses. Is there someway to use VFW drivers instead of WDM in Windows XP ? Do anyone have a solution ?
Please help me![]()
That's XP for ya. I have a Pinnacle Studio Pro card and XP wouldn't even recognize it at all. Gee Whiz Billy Boy Gates....thought XP was supposed to be the Super Duper multimedia OS. "Blah!!!..." I switched back to 2K and all is well again. If your hardware is older than 2 weeks old....XP probably won't work with it.
WDM driver should be Ok.
Try to use DirectShow application for capturing (like iuVCR, FlyDS, amcap) - you will be able to capture at ###x576.
but under xp you can have other problems, like a/v out of sync etc. -
Thanks ! For the help !
The DirectShow capture programs worked fine! With high resolution, and "iuVCR" seems to be a good capture program.
Hauppauge compatibility
By dfisher052 in forum ComputerReplies: 12Last Post: 29th Jan 2011, 02:59 -
Hauppauge or AverTv??
By markypizz in forum Capturing and VCRReplies: 4Last Post: 11th Jul 2010, 16:28 -
Hauppauge HD PVR
By karebo in forum DVB / IPTVReplies: 13Last Post: 6th Jun 2009, 09:57 -
Has anyone tried the Hauppauge 2250 yet?
By TooLFooL in forum Capturing and VCRReplies: 5Last Post: 16th Nov 2008, 05:07 -
Hauppauge and ATI in same PC
By chris1379 in forum Media Center PC / MediaCentersReplies: 2Last Post: 13th Jun 2007, 21:40
