I replaced my two-year old hard drive with a new one. I did not erase anything hoping I can use it as a backup. I put it inside a static-free plastic. My question is - will it last longer as opposed to being connected as slave in a PC? I am concerned that it will do more harm than good being dormant in that plastic bag. On the other hand, if it is slaved, it will continue spinning that will cause rapid wear and tear. Some expert advice please. Thanks.
Stored in a sealed anti static bag it should last a long time. If you have some silica gel packages (That are dried first!) you could put them in there also.
After quite a few years the data may fade as it's just magnetic fields on the HD platter. Remember a HD originally come in a sealed anti static bag and is made to survive years on a shelf.
Use it gently at first if it's stored for a long period to give the bearings a chance to 'loosen'.
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 19:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 18:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 13:42 -
Hard-Drive write caching,Is my hard drive faulty
By jezzer in forum ComputerReplies: 33Last Post: 27th Sep 2008, 11:06 -
Replace Dead Hard Drive From DVR 533HS With Working Hard Drive From DVR 640
By gordo1811 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Dec 2007, 15:58
