hey all,
I having a problem,
I am making an anime disc that is 11 episodes long. But 6 episodes are in english and the other 5 are japanese with subtitles.
I had both english and japanese in audio track 1 and I went to compile and it gave me a warning that languages were not the same in the audio track. It told me to seperate them into 2 vts. So I did that. But now I cannot link the two vts's. I tried using vmg menus but they will only link to "normal" menus via the root menu and I need multiple links from the vmg menus in order to keep my other normal menus correctly.
here is an example of what I have been trying to do.
menu-> menu-> vmg-> two menus to seperate english and japanese episodes-> episodes scenes
main menu->dragonball 134,137-> dragonball z episodes-> english 190-194
->japanese 210,216-219-> scenes
will dvd players play a dvd that has two different languages in the same track?
thanks for any help,
sincerely,
schunn99
You can either
1. Look at bridging in the manual
2. Create a dummy (empty) AC3 file and add it as audio one on all Japanese audio clips, with the japenses audio in track two. Mark the empty track as English. Add it as track two on all English audio clips and mark it Japanese audio. You should now be able to compile all clips in a single VTS because all the audio matches. Many commercial disks use dummy audio tracks for this purpose.Read my blog here.
I was thinking of doing your number two suggestion. but how do you make a dummy audio file?
DVD-Lab pro menu problem
By wackman in forum Authoring (DVD)Replies: 4Last Post: 26th Aug 2008, 05:52 -
Subtitles problem in DVD-lab pro
By spyart in forum Authoring (DVD)Replies: 1Last Post: 25th Aug 2008, 16:14 -
DVD Lab Pro compilation problem
By JohnCPun in forum Authoring (DVD)Replies: 11Last Post: 8th Jan 2008, 17:31 -
Problem with DVD LAb Pro...
By GangstaRap in forum Authoring (DVD)Replies: 19Last Post: 20th Dec 2007, 14:23 -
DVD-lab pro compile problem
By Sats in forum Authoring (DVD)Replies: 8Last Post: 11th Sep 2007, 16:13
