hi all used tfm to merge and convert to avi files to correct video fps and audio fps using avicodec to check the vob files they came out correct format but whne i play the vob files its like listening to a chipmunks album what went wrong can anyone tell me?????
Probably not, without you explaining in quite some greater detail what you started with, what you did with it, using what, and what you ended up with...Originally Posted by hades8840
/Mats -
ok no problem had two avi files from avicodec this is there original specs
File : 226 MB (226 MB), duration: 0:47:00, type: AVI, 1 audio stream(s), quality: 14 %
Video : 207 MB, 618 Kbps, 12.500 fps, 352*288 (4:3), MP43 = MS MPEG4 V3, Supported
Audio : 18.84 MB, 56 Kbps, 24000 Hz, 2 channels, 0x55 = MPEG Layer-3, Supported
File : 227 MB (227 MB), duration: 0:47:13, type: AVI, 1 audio stream(s), quality: 14 %
Video : 208 MB, 617 Kbps, 12.500 fps, 352*288 (4:3), MP43 = MS MPEG4 V3, Supported
Audio : 18.93 MB, 56 Kbps, 24000 Hz, 2 channels, 0x55 = MPEG Layer-3, Supported
as they was both same i used film machine to convert them to pal that used virtual mod to merge them and the other programs to convert them to the correct format but something went wrong as like i said sound like chipmunks
i ended up with vob files in the dvd folder two bup files and two ifo files the vob files are as follows from avi codec
File : 1023 MB (1.49 GB), duration: 0:22:08, type: MPG, 1 audio stream(s), quality: 75 %
Video : 1.46 GB, 9384 Kbps, 25.0 fps, 720*576 (4:3), MPG2 = MPEG 2 (SVCD/DVD), Supported
Audio : 30 MB, 192 Kbps, 48000 Hz, 2 channels, 0x51 = Mpeg-1 audio Layer 2 [0xc0], Supported
File : 1023 MB (1.48 GB), duration: 0:22:04, type: MPG, 1 audio stream(s), quality: 75 %
Video : 1.45 GB, 9384 Kbps, 25.0 fps, 720*576 (4:3), MPG2 = MPEG 2 (SVCD/DVD), Supported
File : 131 MB (0.00 B), duration: 0:00:00, type: MPG, 1 audio stream(s), quality: 75 %
Video : 0.00 B, 9384 Kbps, 25.0 fps, 720*576 (4:3), MPG2 = MPEG 2 (SVCD/DVD), Supported
Audio : 0.00 B, 192 Kbps, 48000 Hz, 2 channels, 0x51 = Mpeg-1 audio Layer 2 [0xc0], Supported
hope this helps -
Problem is that you have a crappy VCD re-encode where the audio samplerate has been cut in half.
Do yourself a favour and delete it.
If you really want to waste time converting, then try something else to resample the audio or check for a newer version of TFM as this is a known issue. -
The problem is that the original is only 12.5 fps and will never look good. I'd just forget it. If you have to have this video then convert with something like TMPGEnc Plus first.
Good Luck -
ty all for answering and i do want this movie i am looking for another source and i have TMPGEnc Plus 2.5 so will try once i work out to use it so many tuts out there and none seem to get to the exact problem ur having so is hard for a newbie
thanks anyway -
Well just open TMPGEnc Plus and use the wizard. Pick whatever you want to output, IE VCD,SVCD,DVD, NTSC or PAL.
Good Luck
Converted HD wmv to avi but won't get sound in media player device
By Moth Queen in forum Video ConversionReplies: 2Last Post: 20th Jul 2011, 18:24 -
Problems with FLV files that I've converted to AVI
By Diana (Cda) in forum Video ConversionReplies: 5Last Post: 9th Dec 2010, 15:09 -
No video only sound in the beginning of the converted file from AVI to DVD
By lankafta in forum ffmpegX general discussionReplies: 1Last Post: 21st Jul 2009, 23:16 -
Converted avi files darker than originals (avi to mp4)
By Hal05154 in forum Newbie / General discussionsReplies: 3Last Post: 5th Mar 2009, 20:06 -
Converted rmvb Real Media to avi - no sound
By mano1438 in forum Video ConversionReplies: 2Last Post: 25th Aug 2007, 14:28
