im having a problem when frameserving with virtualdub, when i try to open the .vdr file cce 2.5 closes/crash.
what can i do, i have win xp
thanks
Try installing the handler for Virtualdub...follow these instructions step by step and you should be all set, even with WinXP
http://www.vcdhelp.com/virtualdubframeserve.htm -
i found out!!!
in virtualdub if you put a tick in "no audio" it wont works.
if yoy put a tick in " avi audio" cce will open the vdr file normaly.
but what now, can i use the foolproof guide, or something as to be done diferent?
hmmm.. maybe you've just solved my problem! I'll try that out...
Problem with opening AC3 in VirtualDub
By andy_blah in forum AudioReplies: 5Last Post: 6th Nov 2012, 16:25 -
Problem opening mpeg2enc binary
By itegil in forum ffmpegX general discussionReplies: 2Last Post: 6th Aug 2010, 22:48 -
vdub avi file opening problem
By naveenkrish in forum EditingReplies: 3Last Post: 8th Jun 2010, 11:54 -
VirtualDub, problem with *.ts opening
By UMO in forum Newbie / General discussionsReplies: 0Last Post: 27th Feb 2010, 15:50 -
Problem opening Xvid movies in VirtualDub
By wombat4 in forum SubtitleReplies: 9Last Post: 24th Jun 2009, 09:23
