  1. Does anyone know where I can get a .lib or .dll containing ffmpeg, or specifically libavcodec?
    Been trying to compile the source code in VC6, but of course it doesn't compile . Sure I'll get there eventually, but then I can't be sure if it's all going to work.
  2. Originally Posted by DEmberton
    Download the latest Daily Source or better the latest official released Source of ffmpeg. Do look in the ffmpeg documentation how a win32 build will be compiled as you should use for compiling MinGW32 or CygWin. The resulted files are avcodec.dll and avformat.dll.
    May 2010
    Earth... still
    Umm, the question was "where I can get a .lib or .dll..." and you recommend downloading source code?
    source code???
    not equal .dll!!!
    DEmberton was clearly asking for a binary. Please try to read the posts before responding. (Referring the member to the documentation does not count.)
  4. you can find precompiled builds and full sources here
    http://ffmpeg.arrozcru.org/autobuilds/
