    Jul 2005
    europe
    Hello,
    I try to chance the slide media length, when i do 1 slide, it works.
    Is there any way to change all the slides together?
    Standard it is for each slide 5 sec, i want to change it for all to 10 sec.
    How can i do that?
    I now have to do it one by one.
  2. Hi Mark,
    Unable to advise on DVD Architect but if you have a copy of Nero installed and use the Vision Express 3. This gives total controll of each individual slide's duration and \ or all slides within the batch. You also have the ability to request slide duration to fit length of chosen music.
    Kneal
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    I can't see any way to do this other than one at a time. The manual seems to say the same thing. The only way to change all slides together it to add an audio track and tell it to fit the slides to the audio. This will adjust the duration of all slides to fit the duration of the audio. Create a piece of audio that has a length equal to 10 seconds for each picture, add it temorarily, select fit, then delete the audio.
    Read my blog here.
    Jul 2005
    europe
    Ok, I will try your suggestion with the audio, and fit the slides to the audio.
    thanks for the suggestion.
