Which one is best? Or is it just like dvd-r and +r? No best one??
Results 1 to 16 of 16
Best for what?
I guess for all purpose. Short time data back up and maybe a couple movie intros or whatever.
No.
So just look for taiyo yuden or however it is spelled and the best price on them.
Originally Posted by ingeborgdot
Now, if you have a DVD-player, DVD-ROM or DVD-burner that only supports DVD-RW, then DVD-RW may be "better" for you.
But if your hardware supports both, then DVD+RW is IMHO a superior choice.
DVD+R and DVD-R are more "neck and neck" with DVD-R being superior IMHO.
Again, you have to look at what your hardware and intended audience is.
It's pretty clear that there is a lot more high-quality DVD-R media out there than DVD+R, and DVD-R has slightly better compatibility with older hardware. -
Originally Posted by BodysurfWant my help? Ask here! (not via PM!)
Practical answer:
DVD+RW formats on the fly. With Nero InCD4, it only needs ~30sec of initial format to be ready for a 4.3GB transfer.
Also it doesn't need to be closed to play.
Google DVD+RW for more.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
But when I looked at the differences between DVD+RW and DVD-RW, it became pretty evident that DVD+RW is a superior product for the reasons hyped here save the stuff that is no longer true now.
Basically, if you have hardware/an audience that supports both DVD-RW and DVD+RW, I see really no good reason to choose DVD-RW over DVD+RW.
DVD+RW doesn't require lead-in/lead-out times like DVD-RW. DVD+RW doesn't require DVD-Video finalization. DVD+RW has lossless sector linking. And DVD+RW comes is faster speeds (8X) versus DVD-RW (6X).
Of course, YMMV. -
I have scanned a number of different -RW media and the only one I have found that is close to RICOHJPNW11 was some JVW -RW media. Otherwise it was almost unplayable on the first burn. While there is probably good -RW out there it is hard to find so +RW wins simply because of availability.
Still a few bugs in the system... -
I have a chance for a good buy on some verbatim cd-r. How do I know who made them??
But, anyway. The DVD+RW would be my choice... -
Originally Posted by Adder_78
Need Help with Panasonic DVD-LS83 or DVD-LS86 8" Portable DVD Player!
By Big C in forum Portable VideoReplies: 3Last Post: 1st Aug 2011, 17:35 -
Samsung DVD-HR753 DVD and HDD recorder rejected all my blank DVD
By undangltn in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Mar 2010, 12:34 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 08:14 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 17:59 -
DVD+/-RDL Playback on Yamaha DVD-C750, DV-C6770, and DVD-C950
By Big C in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Aug 2007, 08:59
