Hi:
is possible Authoring a dvd use Ulead-DVDworkshop like TMPEG DVD Author software to put three or four VCD to one DVD?
then, HOw?
becuse the TMPEG DVD Author menus which I don't like,I like the Ulead-DVDworkshop better,can someone help??????????
thanks
Well, it'll accept VCD spec MPEG1 files for authoring DVDs, converting only the audio from 44.1KHz to 48KHz, since VCD video is a valid DVD spec, if that's what you mean.
DVDWS2 does not accept MPEG-1.
Mine does.
Note that the arrow indicates that DVDWS2 will not convert an MPEG1 VCD-spec video when authoring a DVD, as the Convert to Disc Template box is left unchecked by the program. Under the Audio tab the box is checked by the program, since the 44.1KHz audio must be converted to 48KHz.
the clip I input are already conver ,I use Tmpge to
canver from rmvb to mpg also (48khz audio),is the DVDWORKSHOP can be cut the clip?like TMPGEnc DVD Author?but anyway,if I don,t want the thumbnail as my menu ,I want word instead.
thanks
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 22:13 -
Ulead Moviefactory
By acw in forum Newbie / General discussionsReplies: 10Last Post: 24th May 2009, 00:51 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 16:11 -
How much do you work? (work = doing something you are getting paid for)
By Baldrick in forum PollsReplies: 20Last Post: 26th Nov 2007, 15:35 -
Ulead crashing
By chewie8008 in forum Authoring (DVD)Replies: 5Last Post: 12th May 2007, 08:57
