hi guys
for the first time in my life I used CCE to re-encode a movie and using 6pass , the quality was okay but after remux it back and burn it, it is playing jumpy in my stand alone dvd players while it play smooth on my pc...
what should I do to skip re-encoding again? and how to set field order in CCE 2.70?
should I open it with restream and uncheck the TOP field and reproduce it again?
I never knew about the field order testing with tmpgenc so I just checked and the original movie seems to have a TOP field (A) and the CCE result is botton field (B) and I'm not so sure how to fix it...
thanks
Need info on field order for capturing mpeg video
By snafubaby in forum Capturing and VCRReplies: 3Last Post: 22nd Dec 2010, 07:58 -
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 00:38 -
Problem with field order on captured video
By brassplyer in forum EditingReplies: 8Last Post: 3rd Apr 2009, 06:06 -
Swapping field order in progressive video.
By jmail524 in forum Video ConversionReplies: 1Last Post: 3rd Aug 2008, 12:53 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 16:14
