Hi
I did successfully created three dvd's from mini dv to dvd.
but now when I am trying to make one audio is not good and video stuck.
I noticed that diff is sp and lp recording.
I am using dvd santa
also tried tmpng and other authering tools.
thanks in advance please help wasted all my weekend doing this and wife is not happy.
vrod
LP mode works by foregoing error checking in favour of putting more data in the same space. This may be the cause of your problem. I also wouldn't trust DVD Santa with anything slightly difficult, but that's just a personal feeling about the product. If you are happy with it, fine.
That said, if you can transfer it across to the PC using firewire, it should be ok to work with.
Does the DV avi file play back OK on the PC ?
Does the authored DVD play OK from the HDD ?
Does the burned disk play OK in the PC ?
What media are you using ?Read my blog here.
This is absolutely false. The only difference between SP and LP is the spacing of the data on the tape. LP just packs the data tighter on the tape making it less compatible from player to player.Originally Posted by guns1inger
http://www.videouniversity.com/dvformat.htm
The consumer-oriented DV uses 10 micron tracks in SP recording mode. Newer camcorders offer an LP mode to increase recording times, but the 6.7 micron tracks make tape interchange problematic on DV machines, and prevents LP tapes from being played in DVCAM or DVCPRO VTRs.
But thanks for playing..... -
DVCAM uses 15 micron spacingOriginally Posted by MpegEncoder
DV SP uses 10 micron spacing
DV LP uses tighter spacing.
The reason DVCAM uses 15 micron spacing (40 min per 1hr tape) is to assure that a tape can be recorded on a camcorder and played back to a different player without extreme mechanical calibration. There is no difference in the DV signal recorded.
The original assumption for 10 micron consumer DV was the video would be played back on the same transport (camcorder). This was all SONY thinking. Panasonic thought 10 micron was OK for DVCPro.
Time shuttle ... 2 yrs
Sony implies Panasonic was correct. 10 microns works for moving between machines, so LP can be used with tighter track spacing for 90min playback on the same transport.
Sony was overly conservative the first time and over-reacted with LP. LP is risky on the same transport over time and is not that good on a different transport.
If you record LP, transfer it quickly while you can.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
The LP issue is settled as OK if you can play the transferred DV-AVI file on the PC after transfer.Originally Posted by vrod
Next issue is how are you encoding MPeg2 and authoring the DVD.Recommends: Kiva.org - Loans that change lives.
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 13:21 -
JVC HR 9600....edit mode vs auto mode for digitizing s vhs or vhs
By fuzzblaster in forum Capturing and VCRReplies: 21Last Post: 21st Jan 2011, 09:28 -
harman kardon dvd28 - problem with dealer mode
By straightedge in forum DVD & Blu-ray PlayersReplies: 1Last Post: 18th Dec 2009, 00:22 -
(sloved) Windows 7 problem reading dvdrw in vro mode
By Wizard23 in forum ComputerReplies: 5Last Post: 19th Nov 2009, 21:21 -
Advantages of ripping in File mode over ISO mode...
By hiimbored in forum DVD RippingReplies: 9Last Post: 5th Jun 2008, 16:27
