I bought a copy of Battle of Britian only to find out it is in PAL format. I want to convert the entire disc including menues and chapters to NTSC. I find guides on how to convert a file from PAL to NTSC but not a whole disc. Can someone please tell me how this can be done. Thanks
Boxingjunkie
Results 1 to 11 of 11
https://www.videohelp.com/forum/viewtopic.php?t=267229
but it isn't worth it...
. i haven't seen any guide for it.
Just make sure you get one that does the video conversion - just because it may be region free doesn't mean it will convert the video standards for you too. That is, by comparison, a relatively rare beast.
Reauthoring PAL to NTSC will probably take you months (in time) to master.
Read the FAQ's on this site to figure out which DVD players are both region free and multi-standard playback (PAL to NTSC).*
http://www.dvdoverseas.com/dvd.htm
Most region free Chinese players will play it in PAL, but then you would need to buy a multi-system TV to watch it in PAL.
Good Luck.
* Beware of falling for "plays any DVD". True it will play any region DVD but that doesn't mean it will play it in NTSC standard. Read carefully.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Here's several different multi-region machines that do format conversion:
http://cgi.ebay.com/ALL-MULTI-REGION-CODE-ZONE-FREE-PAL-NTSC-DVD-PLAYER_W0QQitemZ57962...QQcmdZViewItem
http://cgi.ebay.com/NEW-DAEWOO-ALL-MULTI-REGION-CODE-FREE-DVD-PLAYER-PAL_W0QQitemZ5796...QQcmdZViewItem
http://cgi.ebay.com/New-PIONEER-ALL-MULTI-REGION-CODE-ZONE-FREE-DVD-PLAYER_W0QQitemZ57...QQcmdZViewItem
http://cgi.ebay.com/New-JVC-XV-NP10S-ALL-MULTI-REGION-CODE-FREE-DVD-PLAYER_W0QQitemZ57...QQcmdZViewItem -
costco do daytek and ILO that will play all regions and convert and probably be made protection free, nice units if treated with care, avoid cyberhome.
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
The Cyberhome player can do PAL, but it skips frames and the picture is jittery. I have the Phillips 642. You can get it cheap most places, and it plays almost everything.
https://www.videohelp.com/dvdplayers.php?DVDnameid=4117&Search=Search&#comments
You are in breach of the forum rules and are being banned. You have been warned about this.
/ Moderator John Q. Publik -
Does this Philips unit play consistantly with no skips or dropped frames? And what do they run ($) while I have you on the line?
I have been using the cyberhome unit, and while the picture is beautiful, it does have issues with some discs for no real reason. Sometimes I have to burn a copy and use the new copy to play the PAL disc, and output to NTSC. But the progressive out has proved to be exceptional looking captured into a ADVC-500. No complaints with the output quality once it agees to play the disc smoothly.
Jeff -
my 2 cents on this..
i have a pioneer dv-270 (dv-271, dv-275), it cant be made region free.. but it will play a regionfree (backup) pal dvd-r in ntsc. it converts on the fly and does a wonderful job.. it's a sturdy player, and its about $50 at wal-mart.
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
entire disc rip Drilbit Taylor Region1
By greenapple in forum DVD RippingReplies: 1Last Post: 13th Jul 2008, 04:09 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19 -
Can DVD Recorder copy an entire disc?
By coody in forum DVD & Blu-ray RecordersReplies: 7Last Post: 24th Jan 2008, 12:08 -
PAL to NTSC DVD [Full Disc] Conversion (hybrid method, very easy)
By LadyLiete in forum User guidesReplies: 28Last Post: 5th Nov 2007, 21:35
